Trouble with a remote logging iRule
So this should be a very simple iRule but I’m stumped. The purpose of this iRule was to log on a remote syslog server the external IP of any clients that connect to a specific Virtual Server. I’ve reviewed a number of other threads and I look to have the rule right but when its enabled on a VS it the site just goes to a connection reset error message.
when CLIENT_ACCEPTED {
log 10.33.116.27:5514 local0.info “Client Connected, IP: [IP::client_addr] to XXXXX”
Thanks for any thoughts you can provide.
a better way to do this is the following
    set hsl [HSL::open -proto UDP -pool ]
     HSL::send $hsl "Client Connected, IP: [IP::client_addr] to XXXXX"
I gave this a chance since the other option I had was less desirable. I setup the HSL options and pool and then added this iRule. I show logs of the F5 of the rule being successfully applied. That said I’m not seeing anything new coming into the syslog server. I’ll poke at it for a little while and see if I can get it to work. As a side note, this site won’t be accessed on a huge scale so in-line processing to a remote log server is completely acceptable. If I can get the syntax right would also work.
If you want true remote syslog then follow this 404 Page not found | BIG-IP Documentation
