Trap SNMP events in SCOM
Using the BIG-IP SCOM management pack, I would like to set up SCOM to capture SNMP traps sent by the BIG-IP. Ideally, I would like to capture an SNMP trap that is triggered by the LB_FAILED event. Is this possible?
If you don’t get a response here, you might try posting in the SCOM forum:
Post your general questions about using the Managment Pack as well as input on how it can be enhanced.
http://devcentral.f5.com/Default.aspx?tabid=53&view=topics&forumid=61
Aaron
Not sure about SCOM, but you can send off an SNMP trap using custom alerts as described in SOL3727:
404 Page not found | BIG-IP Documentation (Click here
To trigger the alert, just enable logging in the iRule which has the LB_FAILED event:
when LB_FAILED {
    whatever your action is
    log local0. "Client [IP::client_addr] has hit LB_FAILED"
So then your custom alert would look something like:
alert LB_FAILED_NOTICE "Client (.*) has hit LB_FAILED" { sn
 mptrap OID=".1.3.6.1.4.1.3375.2.4.0.500" }
That OID is made up as described in the SOL.
Denny
