Translating 4.5 i-rules to Ver 9
Help,
I have a some units on 4.5 that load balance by rules. I have to issues when I translate this to version 9.2
The first is as follows: -
elseif { [HTTP::payload length] < 20 } {
log “accumulating…”
Accumulate
the problem is that during programing this is accepted but when running the unit throws up an error saying does not reconise command accumulate. Does any one have any idea what this should be with the new syntax.
The second is to do with the regular expression syntax. The old syntax translates as follows (in theroy).
else {
if { [HTTP::header “X-WSB-msisdn”] matches_regex “[01234]$” } {
use pool mmsny1_pool
log “mms: 01234: NY”
elseif { [HTTP::header “X-WSB-msisdn”] matches_regex “[56789]$” } {
use pool mmsbe1_pool
log “mms: 56789: BE1”
else {
log “mms: missed msisdn”
Problem is with the regular expression in the square brackets as per 4.5 the UIE rejects the script as it thinks this is a function. Removal of the square brackets prevents the script from compareing the regular expression. Any ideas on what replaces the square brackets.
For the accumulate question, you’ll need to use the HTTP::collect method (if you are in an HTTP event which it looks like you are. For a HTTP request, here’s is something that you could use to collect the payload:
   if { [HTTP::header exists "Content-Length"] } {
      set content_length [HTTP::header "Content-Length"]
      set content_length 4294967295
   if { $content_length > 0 } {
      HTTP::collect $content_length
when HTTP_REQUEST_DATA {
   HTTP::payload will now contain the content
As for the matches_regex, you’ll need to surround your regular expression with curly-braces.
else {
  if { [HTTP::header "X-WSB-msisdn"] matches_regex {[01234]$} } {
    log "mms: 01234: NY"
  } elseif { [HTTP::header "X-WSB-msisdn"] matches_regex {[56789]$} } {
    log "mms: 56789: BE1"
    log "mms: missed msisdn"
Another option would be to use the builtin TCL regexp command. That usage would be the following:
else {
  if { [regexp {[01234]$} [HTTP::header "X-WSB-msisdn"]] } {
  } elseif { [regexp {[56789]$} [HTTP::header "X-WSB-msisdn"] ] } {
The TCL Reference for regexp gives an example of enclosing the variable in braces.
Click here
But, Regular expressions are very expensive resource-wise. If you are just looking for the last character to see if it’s a number in your ranges, you could also do something like one of the following:
else {
   extract last character in header
  set last [string last [HTTP::header "X-WSB-msisdn" end]
  if { ($last >= 0) && ($last <= 4) } {
  } elseif { ($last >= 5) && ($last <= 9) } {
-or-
else {
  switch $last {
    0 - 1 - 2 - 3 - 4 {
    5 - 6 - 7 - 8 - 9 {
    default {
It’s probably a toss up which one has lower overhead.
-Joe
