Traffic Load Handling.
we have too much traffic load from some specific client IP’s and i want to make a separate pool for that clients. so that if request comes from their network that should be routed to separate pool.
What are the possiable ways to do that.
You can use iRules for that:
rule myrule {
when CLIENT_ACCEPTED {
set vs “[IP::local_addr]:[TCP::local_port]”
if {[IP::addr [IP::client_addr] equals 172.28.19.0/24]}{
pool foo1
pool foo2
Or if you have many subnets, you can change the iRule to use a datagroup with the defined subnets in it.
