traffic coming over APM XforwardedIP not being recorded by IIS
Environment :
  1. IIS windows host : Windows 2008R2 server
  2. f5 : 12.1
  3. Basic virtual server : http only - one server in the pool
Handling a strange issue. virtual server has x-forwarding http profile turned on. It records all x-forwarded IPs expect for the traffic originating from VPN clients who are getting i.e. 192.168.10.0 IP range.
Capture on the windows host clearly suggests that X-forwarded stamp is being passed through but IIS logs doesnt have any reference. IIS logs only records the selfIP of the f5 and not X-forwarded stamp. IIS logs configs are set to capture everything.
I tried installing f5 recommended isapi filter - no effect.
Any pointers will be appreciated.
Hi Jim,
IIS has a very poor support for X-Forwarded-For headers… :disappointed_face:
I usually tend to write the original client IP into an additional cookie (via
HTTP::cookie insert name "OrigIP" value [IP::client_addr]
) and collect those information by turning on IIS cookie logging. Its much easier, doesn require any bits’n’bytes on your servers and may already satisfy your needs… :wink:
If you’re still looking for a native
X-Forwarded-For
support, then take a look to the following blog site. The site outlines and compares different techniques which are more or less supported/maintained by Microsoft or F5.
Cheers, Kai
