I am looking for a way to track the number of connections each pool member has currently and if that number exceeds a value write to the log file.
This is in preparation to setting max connections for each pool member, but we first want to log what would occur for a week or so before we implement the hard limits.
vs_a >> pool_a
pool_a has four members: server_[1-10]
When server_[1-10] is selected, increment the associated variable (server_[1-10]) by 1 and when that connection is closed decrease by 1.
If any of the variables is greater than 100 write an entry to the log file.
I already have the following code to track the virtual server connections, but I am having trouble tracking the pool member connections.
Thanks in advance!
when RULE_INIT {
Set a global max for number of concurrent TCP connections
set ::capture_sco2_max_connections 8800
Initialize a counter for active connections (don't modify this)
set ::capture_sco2_active_connections 0
If we're over the limit for this connection, write to log file
if {$::capture_sco2_active_connections > $::capture_sco2_max_connections} {
log local0. "capture_sco2 has exceeded its connection limit and the status page would have been presented"
else {
incr $::capture_sco2_active_connections 1
when CLIENT_CLOSED {
Decrease capture_sco2_active_connections by 1
incr $::capture_sco2_active_connections -1
