TPS Calculation with 4 Cores on B2150 Blades on VPR C2400
Calculating of Maximum SSL Session. Devices are
Chassis: C2400
Blade: B2150
As per documentation B2150 can have below numbers
SSL Keys: 2048(2K)
SSL TPS: 4000/Blade
Maximum SSL TPS: 10000 TPS
SSL TPS per core: 500
Each Core can handle: 5 session each 10ms cycle
config tmsh show sys performance throughput
SSL Transactions Current Average Max(since 02/23/17 07:26:59)
SSL TPS 10 10 13
So the question are
how many TPS session are possible with the 4 cores? Is it 20 ?
what does SSL TPS: 4000/Blade and Maximum SSL TPS: 10000 TPS means ?
Can in increase number of TPS by increasing number of Cores ?
Looking forward for the response
Sunny
Have a look in this solution:
When looking total TPS for a unit, you have to divide per number of TMMs. Based in the solution, when looking the license, you have to multiple per number of TMMs.
