I have SSL certificate imported in my LTM. I want to disable Export option in GUI. How to do it.
You can’t disable exporting certificate but you can add addtional protection by setting a password (encrypt key) during key generation (before importing it to f5).
otherwise it would be necessary to use an HSM.
