TMSH commands to create cert-key-chain set
How to create cert-key-chain set on LTM using TMSH commands ? There is a K-page on how to add multiple certs to a single profile but I’d like to know how we can do it using tmsh. myF5
Hello,
This command should work
tmsh create ltm profile client-ssl clientssl-profile-name { cert your_cert.crt key your_cert.key chain theChainCert.crt }
Please give us a feedback
Regards
So I found a solution, we can add multiple certificate and key pairs to one client-ssl profile. This can be done using the cert-key-chain set, below is the tmsh command:
create ltm profile client-ssl SSL_NAME { cert-key-chain add { RSA { cert RSA.crt key RSA.key chain chain.crt } ECDSA { cert ecdsa.crt key ecdsa.key chain chain.crt } }
Thanks.
