I was hoping to get some assistance in executing TMSH commands via the Python SDK. From the documentation i can easily execute any BASH command but i’m struggling with TMSH commands.
I need to execute the following including console output.
run /cm config-sync to-group Syncfailover
and slso check the status with
show /cm sync-status
- Expected console output for show
- CM::Sync Status
- Color green
- Status In Sync
- Summary
- Details
- /Common/host1.company.com: connected (for 2548 seconds)
- /Common/sync-fail-test (In Sync):
- - all 2 devices consistent
- /Common/device_trust_group (In Sync):
The Documentation doesn’t really give a noob like me information for achieving above. They only mention a very simple example in saving a config. ie
mgmt.tm.sys.config.exec_cmd('save')
Thank you very much for the effort Dario! I’m going to try and figure something out with my very limited coding skills.
Hello Rudi.
Here an example to get access to the status object
from f5.bigip import ManagementRoot
session = ManagementRoot("F5_mgmt_IP","username","password",token=True)
status = session.tm.cm.sync_status.load()
print(status.raw)
In general in SDK there are 3 kind of objects, here is some documentation.
Tutorial for accessing
- Collections
- Named Resources
REF - https://devcentral.f5.com/s/articles/getting-started-with-the-f5-common-python-sdk-27438
REF - https://devcentral.f5.com/s/articles/getting-started-with-the-python-sdk-part-2-unnamed-resources-and-commands-27602
Hope this helps.
KR,
Dario.
OMW Dario, you are such a life saver!!! I’m going to try this right now! Thanks again for your incredibly valuable input sir!!
You are welcome
BTW, I would appreciate if you mark the answer as ‘the best’ or give me some upvotes.
KR,
Dario.
