Yes, doesn’t appear the one-line modifier is applicable to that command. Suspect it’s because there is a lot of dependency that the command needs to show and it can’t (or isn’t ideal) to put it all in one line.
This really is more of a parsing bug. Once you add properties to the command it no longer interprets an option.
list /ltm virtual description one-line
Syntax Error: “one-line” unknown property
I would think that output formatting options could be honored, even with a subset of the full data. This should be corrected in the command line parser.
i recommend opening a support case and requesting the feature. it would definitely be a nice additional feature to tmsh if one-line worked when specifying options.
