tmsh command (displaying multiple select properties rather than all of them)
I’m displaying my cert profiles using tmsh and am wondering what the syntax is if I want to display more than one property at a time , rather than use “all-properties”.
Example: Combine the output of these two commands:
tmsh list ltm profile client-ssl ciphers
tmsh list ltm profile client-ssl options
Thanks!
Yes, Its Possible. Find the below output.
Ciphers
root@(abc)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm profile client-ssl clientssl ciphers
ltm profile client-ssl clientssl {
    ciphers DEFAULT
root@(abc)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm profile client-ssl clientssl options
    options { dont-insert-empty-fragments no-tlsv1.3 no-dtlsv1.2 }
Ciphers+Options
tmsh list ltm profile client-ssl clientssl ciphers options
root@(abc)(cfg-sync Standalone)(Active)(/Common)(tmos)# list ltm profile client-ssl clientssl ciphers options
    ciphers DEFAULT
Hope it works for you
