TMOS OID for new connection counts per Virtual Server
Hi, guys.
Can i get new connection counts per virtual server form the MIB(SNMP)?
I installed cacti, but i can’t find the OID for VS new Connection count from MIB.
I would appreciate your prompt reply.
Can i get connections entry(number) per virtual server form the MIB(SNMP)?
is this what you are looking for?
[root@ve11b:Active:In Sync] config  snmpwalk -v 2c -c public localhost f5|grep -i clientcurconns |grep telnetvs
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientCurConns."/Common/telnetvs" = Counter64: 1
[root@ve11b:Active:In Sync] config  snmptranslate -On F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientCurConns.\"/Common/telnetvs\"
.1.3.6.1.4.1.3375.2.2.10.2.3.1.12.16.47.67.111.109.109.111.110.47.116.101.108.110.101.116.118.115
[root@ve11b:Active:In Sync] config  tmsh show ltm virtual telnetvs |grep -i current\ connections
  Current Connections                        1          0        -
Not a total, Per virtual server’s new connetction counts.
isn’t virtual server name (telnetvs) there?
[root@ve11b:Active:In Sync] config  snmpwalk -v 2c -c public localhost f5 |grep -i statclient |grep telnetvs
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientPktsIn."/Common/telnetvs" = Counter64: 36
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientBytesIn."/Common/telnetvs" = Counter64: 1556
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientPktsOut."/Common/telnetvs" = Counter64: 35
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientBytesOut."/Common/telnetvs" = Counter64: 1658
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientMaxConns."/Common/telnetvs" = Counter64: 1
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientTotConns."/Common/telnetvs" = Counter64: 1
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientCurConns."/Common/telnetvs" = Counter64: 0
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientEvictedConns."/Common/telnetvs" = Counter64: 0
F5-BIGIP-LOCAL-MIB::ltmVirtualServStatClientSlowKilled."/Common/telnetvs" = Counter64: 0
Nitass, I got it.
Thank you for your answer. :slight_smile:
