how is this concept useful in f5 load balancer?
Go through F5 document, which will give idea about TMSH and TMOH
https://f5.com/resources/white-papers/tmos-redefining-the-solution -- TMOS
Find here an article that explain clearly and simply what is TMOS. and what it brings to f5 load balancer.
Regarding tmsh:
What is tmsh? Well the first link in this article will tell you a lot, but if you just want the synopsis, tmsh is the shell replacement for BIG-IP’s bigpipe command, only it does much more than bigpipe did. Worried that you don’t want to have to learn tmsh to manage your BIG-IP family products? No worries, bigpipe is still available at this time, but the power of tmsh combined with its scripting capabilities make us certain that you should check it out. bigpipe won’t be around forever, and you can get a lot out of tmsh.
https://devcentral.f5.com/articles/tmsh-is-here-ndash-your-guide-to-command-line-dominance
hope it help you.
regards
