i guess your virtual server may have more than one irule or the irule you posted might not be finished. based on the error, i understand there is traffic which triggers more than one HTTP::request or HTTP::respond.
it dpends on how you code irule. you may use event command to disable other event after triggering the first redirection (HTTP::redirect or HTTP::respond).
