TMM and HMS Hardware Resources
Would anyone be able to explain how TMM and the HMS share resources please? From a hardware point of view TMM is described as a dedicated system and HMS as a seperate subsystem but the TMM software process runs within the HMS so can I assume they share memory and CPU resources? And where the HMS is concerned, on multicore processors, I assume it uses all cores through SMP etc.?
not sure if you have seen this. it might not be exactly what you are looking for but hope it is helpful.
TMOS Secure Development and Implementation
sol3242: Overview of BIG-IP Traffic Management Microkernel (TMM) CPU and RAM usage
Thanks nitass, I’d seen the first document at least but unfortunately neither provide the clarity I’m looking for.
OK, so the lowdown I got was that the HMS only runs on one CPU and has a restricted amount of system RAM assigned.
TMM ‘boots’ and runs within HMS and would fail if the HMS fails.
