Timeout for TCP/SSL Collect
Is there any way to put a limit on the SSL::collect or TCP::collect actions? I can’t seem to find a built in function to do this, and was curious if anyone had a good method to do this.
i think TCP::collect does not need timeout because it will always be fired.
With TCP::collect, the event for processing the data (CLIENT_DATA or SERVER_DATA ) will fire without TCP::release being called
TCP::collect
for SSL::collect, i think after command may be usable.
config
[root@ve11a:Active:In Sync] config  tmsh list ltm rule qux
ltm rule qux {
    when CLIENTSSL_HANDSHAKE {
  log local0. ""
  set mon [\
    after 100 {
      TCP::close
  SSL::collect 1500
when CLIENTSSL_DATA {
  log local0. ""
 client
[root@centos1 ~] curl -d test=1234567890 -ik https://172.28.24.10
curl: (52) Empty reply from server
after
Both TCP::collect and SSL::collect have packet length parameter options. Can you elaborate on what you’re trying to do? Are you trying to perform some function if no data is collected over some period of time? I’d be cautious in the use of an explicit timing function like after. It’s definitely useful here, but can have some implications of CPU utilization.
