timeout for SNAT
Hi ALL:
Is it possible to specify the idle timeout value of SNAT object by iRule ? I can not find any documentation for it.
For example : I have a VS : 100.100.100.30 , then I wish the iRule change the Src IP to 100.100.100.30 for outbound traffic but also the idle timeout is 30 sec . ( I do not create any SNAT object from GUI ).
You can use the IP::idle_timeout command to get or set this value. Check out the Wiki for a little more information: Click here
Colin
