Timeout changes do not work
Hi all,
I need your help!
I need to control the http responses time. If the responses take longer than 1 or 2 second, depending on the requests, a timeout must ‘jump’.
I have tried to modify idle timeout parameter in the tcp profile (300s → 1s) and in the same conditions some times work and other not. I don´t understand.
I have tried to modify idle timeout with IP::idle_timeout in a irule and it doesn’t work …
Thanks.
Hi Pepi,
If you want to selectively change the TCP idle timeout or take some other action X seconds after the HTTP request is sent to the pool member, you might be able to use the ‘after’ command (Click here) in 10.0+ to take an action. I don’t think there is a practical way to do this in 9.x.
Aaron
Hi Aaaron,
Have you ever tried to modify the TCP idle timeout parameter o use IP::idle_timeout command?
Yeah, I added the example to the wiki page:
http://devcentral.f5.com/wiki/default.aspx/iRules/ip\_\_idle\_timeout
Aaron
