HI all,
newbie here
i have a problem Tibco getting timeout from LB when i trying to fire the registration request to SV, how can i check at LB side?please let me now. Below is the URL details which tibco is using to fire the request to LB.
10.xx.xx.xx:54xxx
thank you
best regards, Adit jamblang
Need some more clarity on your question:
Is traffic encrypted?
Have you taken a tcpdump on the client side or server side connection?
tcpdump -nni 0.0 host 10.x.x.x -w /var/tmp (or wherever you want to capture it)
Can you connect from the LTM to the backend servers on the respective ports?
Solved, VLAN and Tunnel Traffic problems
thank you
