Am having one F5 ig IP APM setup whoich is working fine. But one day when I tried to login into the management console, Its showing the error “This BIG-IP system has encountered a configuration problem that may prevent the Configuration utility from functioning properly.”. After login to the console ,its showing the error “The configuration has not yet loaded. If this message persists, it may indicate a configuration problem.” And the configuration which we did before is also not there and no options for creating profiles and it’s like fresh setup. I searched in google regarding this and done with some steps but got failed. . I powered ON this machine after 2 weeks and got shocked with this behaviour. When I used last time , it is perfect and suddenly happened like this. Will you please help me for troubleshooting this issue.
login to cli and run=>bigstart httpd restart
There problem seems to be here:
net stp /Common/cist {
interfaces {
1.0 {
external-path-cost 200000
internal-path-cost 200000
1.1 {
1.2 {
vlans {
/Common/external
/Common/internal
net vlan /Common/external {
interfaces {
1.2 {}
tag 4093
net vlan /Common/internal {
interfaces {
1.1 {}
mtu 9001 tag 4094
You can try and remove the following:
1.0 {
and see if it gets loaded:
tmsh run /sys config load
No harm in trying but back up the conf file somewhere else first before you do this.
when did you upgrade to v 13, before upgrade did you renew the license ?
post the below output from CLI cd /config Config more bigip.license | grep date
@abdul rahman I directly prepared the setup of version 13 in AWS. When I run the License command I got output Licensed date : 20170330 service check date 20170119 .
