Hello,
Using BIG-IP VE (v16.1.3.4) on IBM Cloud (pre-built image).
Whole system works well except for repeating messages (every 2 s) showing up in /var/log/ltm:
Jul 5 07:58:27 bigip-01.qpc err tmsh[18264]: 01420006:3: 01020036:3: The requested self IP (/Common/selfip_1_1) was not found.
There is no such selfip 1_1; I have two interfaces, one for traffic (1_2) with selfip_1_2 (created automatically for me), the other for management (1_1) with no self ip.
Anyone has any idea where this error is coming from ?
@nco-ibm You might be able to generate and SCF using the following link and then parsing through it for selfip_1_1 to see if you can find the reference and correct it.
You can search /config directory via SSH for the configuration file with the selfip_1_1 reference. Modify the file, deleting the refernce, and then reload / save the config.
1) SSH into F5 BIG-IP instance and grep for selfip_1_1 in /config directory.
2) Modify the file with the reference, removing it.
3) tmsh load sys config
4) tmsh save sys config
5) Continue via GUI to configuration as usual.
were you able to work this out @nco-ibm ?
