The node command when using persistance
I have a iRule using uie within a universal persistence profile. I have another irule assigned to the VS which uses the node command. However I see the F5 issues a RST back to the client. If use the pool command instead of the node command it works. Is there some logic or technical reason why this happens.
Thanks,
Have you tried catching the LB_FAILED event (As in the iRule wiki)?
H
Anyone else knows why this behaviour happens.
Thanks,
