Hi I launched the F5 Networks Hourly BIGIP-12.1.1.1.0.196 - Best 200Mbps in AWS and I was able to login and change the password. But when I attach network interfaces to the instance, I get this error: The configuration has not yet loaded. If this message persists, it may indicate a configuration problem. and whatever config am trying, I get this error: An error has occurred while trying to process your request. starting with even VLAN can someone help please?
Hi Latratnam,
You deployed a new F5 VE in AWS, by default you have 4 interfaces (1 for mgmt and 3 others). When is the problem happening?
When you try to add new interface to your VE?
Or trought the GUI when you try to attach an interce to a vlan?
Thank you.
I didnt get4 interfaces by default. What should I select to get 4 interfaces? I used the Instance type c4.4xlarge and I had only management interface and I manually added two additional network interfaces from AWS and attached to F5.
I used the instance type m4.2xlarge and it seemed like working. I did not see the config error anymore after attaching the Network Interfaces. I still didn’t get 4 interfaces automatically though.
