I have a 2 app server (IIS) TFS infra, where i have configured 2 LTM and a GTM. Everything seems to be working fine, other than the GTM url is not secured. My question is, where do i install the certificate? is it in the IIS server where the application is running or somewhere in GTM?
do i need the cert to contain all the cnames into it as alaises?
You would generally install the certificate on the LTM virtual servers that load-balances traffic to your TFS servers, to offload TLS/SSL to the LTM. You may also install the certificate on to your TFS servers to maintain end-to-end TLS/SSL encryption.
If your certificate is not a wildcard for the domain, then you may need to include Subject Alternative Names
