Terminate SSL, and redirect based on subsequent request?
Hi All,
We have an F5 virtual with proxies behind it. For a specific domain, which only accepts connections via SSL, I would like to terminate the SSL connection, decrypt the subsequent GET, and redirect the browser based on the URL of the GET.
This is driving me crazy - has anyone done this? :slight_smile:
Thanks much in advance,
Mark
Can I assume you’re load balancing proxy servers?
If so, is it reasonable to decrypt and then re-encrypt the traffic to the proxy? If so then an iRule to direct traffic via client request would be straight forward.
