We’ve been pretty successful blocking rogue players using a DataGroup and a simple iRule. However, now the goal is to populate this DataGroup dynamically, blocking and unblocking on a schedule, or timer. Is anyone aware of the ability to set ‘timers’ for something like this ?
If you are licensed for BIG-IP Advanced Firewall Manager (AFM), it provides the functionality you are looking for via its IP Intelligence features. I can’t think of a way to do this easily or effectively with an iRule - at least not without severely limiting performance - but perhaps someone else has a suggestion.
Simple example, but you could do something like this to define your schedule. Needless to say, if you want a more complicated schedule you’d need to have more complicated conditions e.g. $curTime is greater than timeA and less than timeB
set curTime "[clock format [clock seconds] -format %H%M%S]"
set pm 120000
if { $curTime < $pm } {
It's AM - Do something
} elseif { $curTime > $pm } {
It's PM - Do something
