Telnet over BigIp
Hi All,
I need to configure BigIp for telnet and SSH traffic.
Kindly help..
Regards,
Rahul
Hi Rahul,
Are you trying to administer the BIG-IP itself using telnet and/or SSH? If so, you can only use SSH or the serial console.
SOL5380: Specifying allowable IP Ranges for SSH Access
Or are you trying to allow administrative access to the servers that you’re load balancing? If so, you can see SOL7229 for details:
SOL7229: Methods of gaining administrative access to nodes through the BIG-IP system
Aaron
