tcpdump raw packet capture
Does anyone know how to perform a raw packet capture using tcpdump? I have found multiple answers online but none seem to work. When I load the capture into wireshark I still see “Packet truncated during capture”.
Hi Brian,
The packets are being truncated because the default packet size capture is tiny. You can use -s 1500 or -s 0 on LTM to capture the full packets.
SOL411: Overview of packet tracing with the tcpdump utility
Capturing Packet Data
The tcpdump utility provides an option which allows you to specify the amount of each packet to capture.
You can use the -s (snarf/snaplen) option to specify the amount of each packet to capture. To capture the entire packet, use a value of 0 (zero). For example:
tcpdump -s0 src host 172.16.101.20 and dst port 80
Aaron
Hi Aaron, thanks worked a treat.
