TCPDump Question
What is the correct format to export a dumpfile to, to be properly read in wireshark? I am having issues with wireshark complaining about my capture files not being valid.
I believe the bigip and wireshark supports many formats.
From SOL13637 you can use .dmp, from SOL411 you can use binary format .bin and I have used .pcap too.
Hope this helps,
N
It sounds like you may be redirecting the text output to a file, which is not what Wireshark wants. Tcpdump can write the packet data to a file in PCAP format. Use the -w option, then you can import that into Wireshar.
