tcpdump on particular interface
tcpdump -ni 0.0:nnnp -s0 host and port -v
when running tcpdump if i want to use a particular interface
instead of 0.0 , how to select the interface or find the
interface which is connected to server or pool member
Hi Gajji,
To view the traffic on a single specific interface:
tcpdump -ni 2.1:nnnp -s0 host 1.2.3.4 and port 443
To view the traffic on a specific VLAN called internal:
tcpdump -ni internal:nnnp -s0 host 1.2.3.4 and port 443
REF: myF5
how to select the particular interface or find the
interface which is connected to server or pool member ??
Hello Gajji,
To find the interface that’s hande the traffic to a specific destination, you can use this command : ip route get
# ip route get 192.168.0.1
192.168.0.1 via 192.168.0.150 dev internal  src 192.168.x.x
