I have a test VIP that load balances to a single web server which I can connect to with no problem over port 80…I’m running version 10.0.1.
I turned up tcpdump to watch the traffic oome in and out on the F5 and it only shows a packet or two every couple of minutes no matter how many times I refresh the browser.
I have tried this same thing for other traffic and the F5 continues not to show all traffic through tcpdump.
The F5 device is not showing any errors on the interfaces, the memory is low and so is the connection count.
yes, I’m using the CLI and tcpdump doesn’t work correctly using this method, it doesn’t show all the network packet and is very delayed when it does work. Anyone see this issue on their boxes?
Do you see ‘x packets dropped’ when running the tcpdump command? If so, you could try to narrow down which packets you’re trying to capture using more exact filters.
Or are you using a FastL4 profile? If so, the packets accelerated by the PVA would not be fully seen by TMM or tcpdump:
The tcpdump utility runs on the Linux Host CPU, which does not receive PVA-accelerated traffic. Therefore, virtual server traffic that is fully accelerated by the PVA chip will not be captured by tcpdump. The PVA chip resides on the switchboard, between the BIG-IP system’s switch subsystem and the host motherboard.
The PVA handles accelerated traffic in the following order:
* The PVA receives accelerated traffic from the switch subsystem
* The PVA transforms the packet in order to redirect the packet to the appropriate pool member
* The PVA sends the packet back to the switch subsystem
Fully accelerated traffic never reaches the internal trunk and is not processed by TMM.
Running tcpdump on a switch interface is rate-limited to 200 packets per second. Therefore, if you run tcpdump on an interface that is processing more than 200 packets per second, the captured tcpdump file will not include all of the packets.
On this particular VIP, I am not using FastL4 but that’s good to know that I won’t see all packets when doing so. I am using the “tcp” profile for this VIP.
Here is my command and some of the output. I never see the “dropped packet” counter increment and I have tried several different swithces in tcpdump command line and all of them give me the same thing:
I just checked and I"m not running PVA on the interface however, I just reread this portion of a previous post which might explain my symbtoms:
“Running tcpdump on a switch interface is rate-limited to 200 packets per second. Therefore, if you run tcpdump on an interface that is processing more than 200 packets per second, the captured tcpdump file will not include all of the packets.”
I’m not sure if I’m exceeding 200pps…is there a command that can tell me that?
The tcpdump using the external host command didn’t render any output at all.
I was able however, to get the pps throughput using NGenius and I’m at around 2000-3000 pps on the inside interface so this would probably expliain why tcpdump is performing so poorly. The thing is, the F5 that I’m testing on isn’t even our production box that pushes alot more packets per second…how do you troubleshoot this box with a broken tcpdump???
The reason I ask is that the F5 is a fairly new deploy for me and I am starting to get calls from the Windows crew that have machines behind VIPS on this box and they want me to troubleshoot their flows and I can’t…I’m I missing something here?
Hello, I have a problem with my ltm, writing tcpdump -ni external port xxxx can not see any kind of traffic passing, I tried with filters and nothing written here .. just sometimes looks good dump, have some idea? thank you very much , sorry my English so bad
