TCP::respond does unicode expansion?!
So I’m trying to send the bytes 0x05 0x86 back to a socks client with TCP::respond
set r [binary format H2H2 05 86]
log “length of response is [string length $r]”
TCP::respond $r
The log prints out: “length of response is 2”
What actually gets sent to the client is: (in hex) 05 C2 86
Where did the C2 come from?!?! I did some experimenting, and every character 0x79 and under works fine, only sends two bytes instead of 3. As soon as you go up to 0x80, it sends three. I looked into it a bit and 0xC2 is a multibyte unicode character that escapes 0x80 and up.
Where is the C2 getting tacked on? I need to send the exact two bytes 0x05 0x86 and can’t seem to manage to get it to work.
I’m afraid this is a known bug. It will be fixed in the next major release. Please contact F5 support if you require a hotfix.
Doh! Thanks for the heads up. I’ll do my best to get my hands on the hotfix.
