we have configured a Virtual servers with Protocol: TCP to handle the request on HTTPS 443 to a IBM HTTP webserver. However i am getting a 404 message while accessing the application using the VIP configured for this new virtual server.
However application works fine, if i directly access the webserver URL.
Generally speaking, a 404 is not going to be returned by the LTM because it’s not a web server. So my inclination is that the request is getting to the webserver, which is responding with a 404.
When you hit the webserver directly, I suspect you are using different URLs which could change the way IHS responds depending how it is configured. To construct an appropropriate test, in my opinion, create an entry in your local hosts file with the IP address of the webserver the DNS name of the VIP. Then you will be hitting the webserver directly, but using the DNS name of the VIP.
