TCP Info Logging
I am trying to write an irule that will log the TCP info that is being sent to and from the server/client. What exactly does the TCP::collect command grab?
TCP::collect gets the raw bytes that are sent. The data collected will be available in the CLIENT_DATA event.
For example:
when CLIENT_ACCEPTED {
TCP::collect 16
when CLIENT_DATA {
 For logging in other events
set cli "[IP::client_addr]:[TCP::remote_port]"
set dataVal [TCP::payload]
binary scan $dataVal H16 hexRep
log local0. "TCP connection ($cli) sent: $hexRep"
When the client connects this will cause (at least) 16 bytes to be collected. It then converts that data to a hex representation and logs it.
