Hi
I have an irule which is working perfectly in version 10, however when i applied same rule on version 11.1, it started throwing TCL errors as follows:
pr 19 15:37:18 tmm1 err tmm1[7725]: 01220001:3: TCL error: /Common/Report_login_logout - can’t read “static::sessionName”: no such variable while executing “HTTP::cookie value $static::sessionName”
irule::
when HTTP_REQUEST
if user hits the root path, then delete the backend application’s session
if {[HTTP::uri] equals “/”}
set thisCookie [HTTP::cookie value $static::sessionName]
if {not ($thisCookie == “”)}
table delete $thisCookie
redirect to scp/login.jsp so that after logging in through APM the user would get
redirected tothe correct path on the SCP backend application
HTTP::redirect “https://report.landmarkeconnect.com/scpreport/login.jsp”
elseif {[HTTP::uri] starts_with “/renderer/access_notfound.php3”}
else if there was an access violation URI called then also clear the cookie
redirect to APM logout
HTTP::redirect “https://report.landmarkeconnect.com/vdesk/hangup.php3”
Any help is appreciated.
BR
