Hello F5 community:
Is there such a way to create an irule which will take the value before the domain, *.test123.com, append it to ) and pull up the contents without changing the URL in the browser?
for example. A user types in help.test123.com in the browser, but it will pull up the site contents from without changing the URL in the browser.
I was able to find the first part on DevCentral forum of which it takes the value before the domain and adds as uri for testing purposes, however I get the following error when I try to save it.
01070151:3: Rule [/Common/ddc-wpchange1.com_irule] error: /Common/ddc-wpchange1.com_irule:8: error: [parse error: PARSE syntax 289 {syntax error in expression " [string tolower [HTTP::host]] ends with $::domain ": extra tokens at end of expression}][{ [string tolower [HTTP::host]] ends with $::domain }] /Common/ddc-wpchange1.com_irule:21: error: [wrong args][HTTP::host [string range $::domain 1 end]]
when RULE_INIT { Set the value for the domain with a leading period We’ll check the host header value for any string the comes before this string and prepend it to the URI set ::domain “.test123.com” } when HTTP_REQUEST { if { [string tolower [HTTP::host]] ends with $::domain }{
Get any part of the host that comes before the domain.
Split the URI using the domain string. Grab the first string that comes before the domain
set subdomain [getfield [HTTP::host] $::domain 1]
If subdomain isn't null, prepend it to the URI
You could also add additional checks here like subdomain doesn't equal "www"
if { not ($subdomain == "") }{
HTTP::uri [concat "/$subdomain[HTTP::uri]"]
Set the HTTP host to the domain
I was able to get it to work using the following syntax:
when HTTP_REQUEST { Check for a non-null length host header if {[string match {[a-zA-Z]} [HTTP::host]]}{
Use string commands to parse the subdomain
set subdomain [string range [HTTP::host] 0 [expr {[string first . [HTTP::host]] -1}]]
Use the getfield command to parse the subdomain
set subdomain [getfield [HTTP::host] . 1]
Use scan to parse the subdomain
scan [HTTP::host] {%[^.]} subdomain
HTTP::header replace Host "www.test123.com"
HTTP::uri /$subdomain[HTTP::uri]
Simpler code :
if {[string match {[a-zA-Z]} [HTTP::host]]} {
HTTP::host "www.test123.com"
HTTP::uri /[getfield [HTTP::host] . 1][HTTP::uri]
