Hello all,
I’m a Big-IP pre-newbie (i.e. this is a pre-sales question!)
I am looking at implementing a load-balancing solution in my organisation, not only to assist with application up-time from using a web-farm, but also from a view of taking apps offline to work on / upgrade them without affecting the users.
I’ve looked on various web pages on the BigIP site and that says about taking ‘servers’ out of a pool, but can I easily take individual virtual folders out of a pool? Here is my scenario:
Two servers (server1 and server2) have various apps on (e.g. app1, app2, app3) - imaginative names I know!
During normal operations requests to these apps will be distributed by the LTM.
I would like to be able to remove Server1\app1 from the pool but still have Server1 responding to requests for the other apps - is this possible?
Thanks in advance for any help you can offer!
Mark
Absolutely.
The load balancing goes from Virtual Server (The IP:Port that listens for inbound client connections on the LTM) to a (Or several) pool. Each pool is comprised of poolmembers which consist of a target IP:Port combination.
So taking one poolmember out from a backend server doesn’t affect others. In fact you can got even further and have the same poolmember in multiple pools and have SOME of them disabled, and some enabled.
H
Thanks for the quick reply Hamish!
So does that mean that each app running on the back-end server(s) will have to have their own IP address / port combination?
Currently our servers expose all apps on a single web-site (and IP address) and we use virtual folders to distinguish between applications - would we have to change this model?
You can still do software virtual servers. But it means you’ll have to provide a slightly modified monitor script for each one (On each pool a different monitor so it specifies the host: header for each one to check availability).
H
