Quick question on how tagged vlans work in a Cisco environment.
I have a switch with a vtp domain in it, its running transparent. Say I configure vlan 1 on it with an ip of 10.1.1.1 255.255.255.0. now I put a second vlan called vlan 2 on the switch and give it an ip of 10.2.2.2 255.255.255.0. I add a new f5 ltm. I configure the f5 internal interface on vlan 2, tag the interface as 2, and associate the correct physical interface. I do the same with vlan 1. I put my pool members in vlan 2 and virtuals in vlan 1. I configure the IP for the internal vlan (vlan 2) and associate it with the correct vlan. Now, I do nothing with vlan 1 on the F5 (as far as configuring an IP). Will the Virtual Servers I configure work without a layer 3 interface configured on the F5 and associated with the External VLAN 1?
If so, can you tell me how?
Thanks,
