TACACS configuration on F5 LTM
Hello All, I’m working on the TACACS configuration on LTM. I do not want to lockout of my access of LTM because of any issue with TACACS authentication issues after enabling TACACS on LTM.
Could you please help me to configure the LTM authentication process as following:
1- First LTM will check with TACACS for authentication
2- If TACACS authentication is failing for some reason of server not reachable or invalid user then it should check with the LTM local user account for authentication.
Can you please help me how to set up this on LTM?
Regards, Thiyagu
Hi Thiyagu,
I assume this is for management access to the F5, correct?
Hi AceDawg, yes it is for management access of F5. as a first step I have also added a route to TACACS through sys management.
Regards, Thiyagu
To the best of my knowledge, the F5 does not revert to the local user db in the event tacacs or radius servers are offline. The only exception to this rule is the built in admin account.
Hi Ace, on accout of TACACS not responding then the user can use the local authentication ( admin account to login)
Could you please help me to know how I can set it up in this method?
in addition I also want to rest the root user password.
Could you also help me to reset root user password?
Regards, Thiyagu
Regards, Thiyagu
if tacacs is enabled you will not be able to use local accounts but root and admin.
If tacacs server is unavailable you will not be able to login using local account but root and admin
Manual Chapter: Remote User Account Management
That is the default behavior of the F5. If tacacs or radius have been configured for management authentication, the F5 will use those methods first. Whether the tacacs or radius servers are online or offline, the local admin (GUI) and root (cli) accounts can always be used to access the system.
To reset your root password, use the following article. You must have console access to the appliance.
Hello the configuration is the following:
External Media
External Media
As per the document it is been mentioned as “In the Secret field, type the password for access to the primary RADIUS server”
Could you please help me to know the mentioned password is the password of the TACACS server or the TACACS server key?
Regards, Thiyagu
Regards, Thiyagu
You would enter the key associated with the F5 client configured on the tacacs server. In other words, the tacacs server should have an entry for the F5 device — enter the key for this entry.
Hello All, One more quick query, Does TACACS configuration auto sync with the other device in the group?
If so If I disable auto sync will it help to test the TACACS in the standby LTM and upon successfull tesitng synchronize with the active LTM in the traffic-gorup?
Regards, Thiyagu
Regards, Thiyagu
Hello Thiyagu,
you can create the password, when you create the group in the TACACs with the devices that you need access, this password key, you have that put in the F5 and associate the integration, but before, you need configure one route management for tmsh, is importan the configuration of the route, if you not put this route the traffic of the connection with the tacacs traveling for the interfaces of traffic.
Hello Thiyagu,
