I do not see much difference between T4 and ALL images
Want to see if anyone have used both and any recommendations on which one to use if we want to deploy only for 1,2 or 3 tenants?
HI @InquisitiveMai ,
Biggest difference is the min virtual disk space needed but from a module support standpoint both offer the same modules. The virtual disk requirements impacts how many tenants you can deploy on the various hardware types. “All” allows for more tenants when compared to “T4”.
A T4 tenant image in F5 BIG-IP does not include all tenant images.
Each tenant needs its own image, and you must upload/install them separately.
Simple idea:
One image ≠ everything
You add only the images you need.
