System.VCMP.VCMPCompletionStatus structure
Hi Chaps
I hope you are all well.
I am doing some work using iControl on perl (SOAP::Lite) to create vCMP instances and am a bit stuck with accessing the data structure returned by System.VCMP.get_completion_status.
I can see it clearly using Data::Dumper, but cant seem to get the code right to be able to access the hash elements.
$VAR1 = [
bless( [
bless( {
‘request_complete’ => ‘true’,
‘comment’ => ‘’,
‘status’ => ‘VCMP_STATUS_RUNNING’,
‘requested_state’ => ‘VCMP_GUEST_STATE_DEPLOYED’,
‘slot_id’ => 1
}, ‘System::VCMP::VCMPCompletionStatus’ )
], ‘System::VCMP::VCMPCompletionStatus[]’ )
Could anybody suggest an example?
Many thanks!
Ross
Here’s a perl example that should get you going:
@list = @{$soap_response->result};
foreach $guest (0 .. $list) {
$ref = $list[$guest];
$n = @$ref - 1;
printf(STDOUT “Guest: %s\n”, $opt_n);
foreach $slot (0 .. $n) {
$foo = $list[$guest][$slot];
$slot_id = $foo->{“slot_id”};
$requested_state = $foo->{“requested_state”};
$request_complete = $foo->{“request_complete”};
$status = $foo->{“status”};
$comment = $foo->{“comment”};
printf(STDOUT “Slot ID: %s\n”, $slot_id);
printf(STDOUT “Requested State: %s\n”, $requested_state);
printf(STDOUT “Request Complete: %s\n”, $request_complete);
printf(STDOUT “Status: %s\n”, $status);
printf(STDOUT “Comment: %s\n”, $comment);
Let’s try that again and see if the system will preserve the indentation:
$n = @$ref - 1;
Hi Mark,
Try putting the code in [ code ] [/ code ] blocks (without the spaces).
Aaron
Thanks! Let’s see how this looks:
$n = @$ref - 1;
printf(STDOUT "Guest: %s\n", $opt_n);
$slot_id = $foo->{"slot_id"};
$requested_state = $foo->{"requested_state"};
$request_complete = $foo->{"request_complete"};
$status = $foo->{"status"};
$comment = $foo->{"comment"};
printf(STDOUT "Slot ID: %s\n", $slot_id);
printf(STDOUT "Requested State: %s\n", $requested_state);
printf(STDOUT "Request Complete: %s\n", $request_complete);
printf(STDOUT "Status: %s\n", $status);
printf(STDOUT "Comment: %s\n", $comment);
One more shot with spaces…
    $n = @$ref - 1;
That’s Perfect.
Thank you very much - I wouldn’t have gotten there on my own!
Kind Regards
Ross
