System::Failover cannot seem to extract result from response data
Using a standard approach to System::Failover and obtaining response data for example:
sub get_failover_mode()
$soapResponse = $Failover->get_failover_mode();
print Dumper ($soapResponse);
&checkResponse($soapResponse);
@Response = @{$soapResponse->result};
$i = 0;
foreach $Response (@Response)
print “$Response \n”;
$i++;
return(0);
For get_failover_mode or get_failover_state I cannot obtain anything from $soapResponse->result.
here is a data dumper of the … $soapResponse.
How to extract the ENUM for ACTIVE or STANDBY state/modes.
$VAR1 = bless( {
‘_content’ => [
‘E:Envelope’,
‘xmlns:y’ => ‘http://www.w3.org/2001/XMLSchema’,
‘E:encodingStyle’ => ‘http://schemas.xmlsoap.org/soap/encoding/’,
‘xmlns:E’ => ‘http://schemas.xmlsoap.org/soap/envelope/’,
‘xmlns:iControl’ => ‘urn:iControl’,
‘xmlns:A’ => ‘http://schemas.xmlsoap.org/soap/encoding/’,
‘xmlns:s’ => ‘http://www.w3.org/2001/XMLSchema-instance’
‘E:Body’,
‘m:get_failover_stateResponse’,
‘xmlns:m’ => ‘urn:iControl:System/Failover’
‘return’,
‘s:type’ => ‘iControl:System.Failover.FailoverState’
‘FAILOVER_STATE_ACTIVE’,
undef,
‘return’,
‘s:type’ => ‘iControl:System.Failover.FailoverState’,
‘{http://www.w3.org/2001/XMLSchema-instance}type’ => ‘{urn:iControl}System.Failover.FailoverState’
undef,
‘return’ => ‘FAILOVER_STATE_ACTIVE’
‘{urn:iControl:System/Failover}get_failover_stateResponse’,
undef,
‘get_failover_stateResponse’ => $VAR1->{‘_content’}[2][0][2][0][4]
‘{http://schemas.xmlsoap.org/soap/envelope/}Body’,
undef,
‘Body’ => $VAR1->{‘_content’}[2][0][4]
‘{http://schemas.xmlsoap.org/soap/envelope/}Envelope’,
‘{http://schemas.xmlsoap.org/soap/envelope/}encodingStyle’ => ‘http://schemas.xmlsoap.org/soap/encoding/’
‘_current’ => [
$VAR1->{‘_content’}
}, ‘SOAP::SOM’ );
get_failover_mode returns a scalar, not an array. Here’s some code that displays the failover state and mode.
!/usr/bin/perl
 use SOAP::Lite + trace => qw(method debug);
 use SOAP::Lite;
 use MIME::Base64;
 sub SOAP::Deserializer::typecast
   my ($self, $value, $name, $attrs, $children, $type) = @_;
   return $value;
  Validate Arguments
 my $sHost = $ARGV[0];
 my $sUID = $ARGV[1];
 my $sPWD = $ARGV[2];
 my $sProtocol = "https";
 if ( ($sHost eq "") or ($sUID eq "") or ($sPWD eq "") )
   die ("Usage: SystemState.pl host port uid pwd\n");
  Transport Information
 sub SOAP::Transport::HTTP::Client::get_basic_credentials
   return "$sUID" => "$sPWD";
 $Failover = SOAP::Lite
   -> uri('urn:iControl:System/Failover')
   -> proxy("https://$sHost/iControl/iControlPortal.cgi");
 eval { Failover->transport->http_request->header
   'Authorization' =>
     'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
 print "==========================================================\n";
 &getSystemState();
 &getFailoverMode();
 sub getSystemState()
   $soapResponse = $Failover->get_failover_state();
   if ( $soapResponse->fault )
     print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
   else
     $FailoverState = $soapResponse->result;
     print "System State : $FailoverState\n";
 sub getFailoverMode()
   else
     $FailoverMode = $soapResponse->result;
     print "Failover mode: $FailoverMode\n";
Hope that helps…
