Problem this snippet solves:
This source code implements the F5 Networks HNV Gateway plug-in that is installed in the System Center Virtual Machine Manager (SCVMM) for integration into a Microsoft Hyper-V environment. The plug-in allows you to use a BIG-IP device or VE to act as a gateway between virtual networks in SCVMM and external networks. That is, with this plug-in, virtual machines can connect to the outside world, using NVGRE tunnels. After you have made this connection, you can configure the BIG-IP systems to provide application services for those virtual machines. The BIG-IQ system is the management endpoint for the BIG-IP systems.
How to use this snippet:
You can find the documentation for it online at the Ask F5 web site: https://support.f5.com
Code :
80931
Tested this on version:
12.0
