Syslog v11 modification
Hi -
I want to only send syslog levels, notice through emergency, but just want notice messages that match
"monitor status".
Like the messages below here:
Feb 12 00:00:13 myf5.com cleansed mcpd[1925]: 01070727:5: Pool member pool_member_ip:801 monitor status up.
Feb 12 00:01:33 myf5.com cleansed mcpd[1925]: 01070638:5: Pool member pool_member_ip:801 monitor status down.
The syntax below is not getting it done. Am I close?
sys syslog {
        auth-priv-from warning
        auth-priv-to emerg
        console-log enabled
        cron-from warning
        cron-to emerg
        daemon-from notice
        daemon-to emerg
        description none
        include "
        filter f_notice {
            match "(.*monitor status.*)";
        filter f_remote_loghost {
            level(notice..emerg);
        destination d_remote_loghost {
            udp(\"172.17.2.49\" port(514));
            udp(\"172.25.6.10\" port(514));
        log {
            source(s_syslog_pipe);
            filter(f_remote_loghost);
            destination(d_remote_loghost);
        iso-date disabled
        kern-from notice
        kern-to emerg
        local6-from notice
        local6-to emerg
        mail-from notice
        mail-to emerg
        messages-from notice
        messages-to warning
        remote-servers none
        user-log-from notice
        user-log-to emerg
can you try something like this?
config
[root@ve11a:Active:In Sync] config  tmsh list sys syslog
sys syslog {
    include "
filter f_custom {
    (level(notice)
    and match(\"monitor status\"))
    or level(warning..emerg)
destination d_loghost {
    udp(\"172.28.24.1\" port(514));
log {
    filter(f_custom);
    destination(d_loghost);
 logger
[root@ve11a:Active:In Sync] config  logger -p local0.notice "Pool member pool_member_ip:801 monitor status up."
[root@ve11a:Active:In Sync] config  logger -p local0.info "Pool member pool_member_ip:801 monitor status up."
[root@ve11a:Active:In Sync] config  logger -p local0.notice "Pool member pool_member_ip:801 monitor status down."
[root@ve11a:Active:In Sync] config  logger -p local0.emerg "Pool member pool_member_ip:801 monitor status down."
 log host (172.28.24.1)
[root@centos1 ~] nc -l -u 514
<133>Apr 17 01:31:22 ve11a notice root: Pool member pool_member_ip:801 monitor status up.
<133>Apr 17 01:31:47 ve11a notice root: Pool member pool_member_ip:801 monitor status down.
<128>Apr 17 01:32:01 ve11a emerg root: Pool member pool_member_ip:801 monitor status down.
config
sys syslog {
    include "
filter f_custom {
    (level(notice)
log {
    filter(f_custom);
 logger
Beautiful! That works. Thanks nitass!
