Syslog Format
Hi All
Has anyone been able to configure the “Remote Syslog Servers” to use RFC5424 instead of RFC3164.
There are articles on how to configure HSL Destinations and Publishers, etc.
All I want to do is change the format that the current configured servers are using.
Thanx
Have you tried something like the tmsh command shown below:
tmsh modify /sys log-config destination remote-syslog  format  rfc5424
I found the syntax in Solution K22122208.
