Syslog Arcsight and remote destination Syslog combined
Hi All,
I have a BIG-IP LTM + ASM installed. Within the ASM I have a logging profile configured that sends the ASM logs in CEF format to Arcsight that works perfect.
I also have a standard Syslog destination configured in the System menu with the same remote log destination, because I also want standard Syslog information to be send to the same Syslog server.
The problem is that it just does not work. If I generate some logs by shutting down a pool there is no traffic sent to the Syslog server. The very strange thing is when I change the IP to another IP that is different than the Arcsight IP it is being sent.
So it seems like if you are not able to combine a ASM syslog CEF and a normal Syslog destination using the same IP destination.
I also tried to restart the syslog-ng daemon but that also did not fix the problem.
Does someone has an explanation for this?
The ASM logging profile might be looking up the routing for the syslog IP in the tmm route-table.
The syslogd is sending syslogs from the management-ip and lookuping up the route in “tmsh sys management-route”
A tcpdump would help pinpoint the issue.
cheers.
Hi Amit,
You are totally right. I was using tcpdump with the option -i 0.0 but that didn’t capture the management packets. So when I started to capture specifically the management interface I did see the traffic.
Case closed.
