Syntext on Irule for NATTING
Hi
I am writing an irule to do some natting (long story i know there are better ways). I know the switch statement has a limitation in the number of functions you can have it do, i.e. SNAT and POOL in one catch. The irule i am implementating is meant to A. if specific IP, SNAT to a specific SNAT pool member. I now have a requirement for a specific IP to SNAT and redirect to another pool. I had syntext errors from F5 so i came up with below, just wanted to confirm this looks logically correct.
when CLIENT_ACCEPTED {
set c_nat 0
if {[IP::remote_addr] equals “10.X.X.25” or [IP::remote_addr] equals “10.X.X.26”}{
$c_nat 1
$c_nat 0
if {$c_nat == 0}{
switch -glob [IP::remote_addr] {
10.X.X.5 { snatpool SNATX member X.X.X.1 }
10.X.X.6 { snatpool SNATX member X.X.X.2}
10.X.X.7 { snatpool SNATX member X.X.X.3 }
10.X.X.8 { snatpool SNATX member X.X.X.4 }
10.X.X.9 { snatpool SNATX member X.X.X.5 }
default { snatpool SNAT }
} elseif {$c_nat == 1}{
pool poo_2
10.X.X.25 { snatpool SNATY member X.X.Y.1 }
10.X.X.26 { snatpool SNATY member X.X.Y.2 }
log local0. "NAT on F5 has failed
what about this one?
   if {[IP::addr [IP::remote_addr] equals "10.X.X.25"]} {
      pool poo_2
  } elseif {[IP::addr [IP::remote_addr] equals "10.X.X.26"]} {
      pool pool_2
      switch [IP::remote_addr] {
         "10.X.X.5" { snatpool SNATX member X.X.X.1 }
         "10.X.X.6" { snatpool SNATX member X.X.X.2 }
         "10.X.X.7" { snatpool SNATX member  X.X.X.3 }
         "10.X.X.8" { snatpool SNATX member  X.X.X.4 }
         "10.X.X.9" { snatpool SNATX member  X.X.X.5 }
As you do SNAT in any case (value of c_nat will be 0 or 1), you can put it all in one switch statement, without the -glob.
     "10.X.X.25" { snatpool SNATY member X.X.Y.1 }
     "10.X.X.26" { snatpool SNATY member X.X.Y.2 }
   if this is your only pool, leave the statement here. Otherwise put it in the switch action
   pool poo_2
Regards
Kurt Knochner
i think Kurt’s example looks simpler. by the way, if i am not wrong, i understand only 10.x.x.25 and 10.x.x.26 using pool poo_2. so, you have to move pool foo_2 into the switch’s code block.
Thanks nitass, doing it without setting the variable does look better. Thanks also Kurt. I will have a play with both.
apparently we pressed submit within one minute :slight_smile:
great minds
cheer :wink:
