Here is part of a code from V4.1
vendors is defined as a data set. I need a translation
from v4.1 to v9.1 on the IF statement
Code:
elseif ($uri starts_with “/Data/uplink” {
if (client_addr == one of vendors) {
pool P_DATA
else {discard}
Thanks in advance.
This should get you going
} elseif { [HTTP::uri] starts_with "/Data/uplink" } {
if { [matchclass [IP::client_addr] equals $::vendors] > 0 } {
pool P_DATA
discard
You might want to convert the elseif line to
} elseif { [string tolower [HTTP::uri]] starts_with "/data/uplink" } {
if you want a case independent match.
Also, If your vendors list is an address list containing netmasks (and you have not upgraded to BIG-IP v9.0.3 or higher), you might want to check out this thread as well for a known issue with matchclass and comparing network addresses with netmasks.
http://devcentral.f5.com/Default.aspx?tabid=28&view=topic&forumid=5&postid=1235
Click here
-Joe
Thanks Joe ,I will give that a try .
Joe, the problem you referred to was fixed a long time ago in 9.0.3.
