on 9.3 code the || betweem two seprate values for example
if { ([HTTP::host] contains “www.example.com”) || ([HTTP::host] contains “www.example1.com”) }{
pool example
in the above would the || act or repersent the or function ?
The reason I am asking is I have some irules in 9 code which I did not write and it uses the || Have been trying to determine what the || dose is it another way of say or ?
thanks
